sisters 3100 pcv hose not sitting tightly
Old Jun 8, 2008 | 12:19 PM
sickofsoyo's Avatar
Default sisters 3100 pcv hose not sitting tightly
Ok, so after doing my PCV valve, I decided to change hers as well. I went to autozone, their website said I needed part 1125, which is the same as my monte carlo... so I got it, did the change, but the hose that connects to the top of the pcv valve doest sit tightly, it actually will just lift off with no effort... anyone know if I have the wrong valve, or need a new hose? Not sure that could be causing it...
Old Jul 13, 2008 | 12:03 PM
purewhitemonte's Avatar
Default RE: sisters 3100 pcv hose not sitting tightly
I would go back to yoour local Autozone and look your sister's car make, model, etc. in the parts book that will list the PCV valve model # to double check that the correct one was picked. If it was, then I would say the hose would need to be replaced. The end of it may streched out some diameterwise from it being wiggled too much to remove it from the PCV valve.
Old Jul 13, 2008 | 12:19 PM
sickofsoyo's Avatar
I managed to fix it, the hose was bent to the side, I just straightened it out and it sits flush now, I believe the rubber book it worn so that will eventially need replacing but it isnt a priority right now. There is a bit of a cylander tap issue im looking into.
Old Jul 13, 2008 | 03:44 PM
scc24540's Avatar
yeah the 60 degree engines seem to have that tapping problem...wonder why
FlamehedCFH
Mar 17, 2013 08:24 PM
chiguy2498c
Mar 24, 2010 09:14 PM
chiguy2498c
Mar 21, 2010 09:22 PM
98monte
Jan 24, 2008 04:41 AM
bdub_02
Dec 14, 2006 09:59 PM
