shorter dogbones
Old Mar 20, 2010 | 11:26 AM
Enzo354's Avatar
STILL SLOW
I cant find the write up... so Ill try my best haha.
Ok so your going to want to wedge a flathead screwdriver in the outer edge of the bushing and spray in some wd40 all around. Now take off the dogbones completely, but put back in the bolt and nut, and tighten it all the way back up, and make sure it is TIGHT.
Now your going to want to put a wrench on the nut, and the other side of the bolt, and pull them both toward you until the bushing turns in its slot, you want the rubber part horizontal in there, not vertically as it was. . If you lubed it enough its very easy and quick to do. Put it all back together and take it for a drive, you will notice it especially on start up. Hope this helps!!!
Old Mar 20, 2010 | 11:32 AM
hey thanks alot, and yes it does help, but if by chance i dont like it, it can be reversed just as easy right. this wont damage anything though right??
Old Mar 20, 2010 | 11:41 AM
Enzo354's Avatar
STILL SLOW
Yep same process just go backwards. And no it cant hurt anything. While you have out your dogbones you could paint them too
Old Mar 20, 2010 | 12:12 PM
by the way i was doing some searching and the write up you were looking for was in my "lowering"section.
Supercharged04
Dec 10, 2014 12:16 PM
04MonteLS
May 6, 2010 12:03 AM
2003supersport
Mar 2, 2009 03:20 PM
