shift kit
Old 03-07-2011 | 01:32 AM
bama_z34's Avatar
Default shift kit
does anyone make a shift kit for the 4t60-e in my 96 z34?
Old 03-07-2011 | 07:21 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
It looks like Trans Go makes one for your car.
SK®4T60E-Jr
4T60E 91-99
With Modulator
Corrects: Light throttle converter shudder. Contains hardened pins and “Tuff” accumulator piston seals to reduce clutch failure due to pin and seal wear, 3rd clutch seal is self expanding. Includes PWM valve, lock-up regulator valve & bushings.
Photo-More Info
Old 03-08-2011 | 01:18 AM
bama_z34's Avatar
i dont know anything about transmissions yet but does that include everything i need to make my trans shift faster and harder?
Old 03-08-2011 | 12:34 PM
zipper's Avatar
Pretty much. The only other thing you could do is have someone tune your PCM to increase the pressure in the shift solenoids.
JaxJim
12-22-2010 01:11 PM
Frosty LS1
08-24-2009 03:14 PM
88ss408
07-24-2009 08:44 PM
fastback4
06-02-2007 08:05 AM
fastback4
05-03-2007 04:31 AM
