shift kit
Old Mar 7, 2011 | 12:32 AM
bama_z34's Avatar
Default shift kit
does anyone make a shift kit for the 4t60-e in my 96 z34?
Old Mar 7, 2011 | 06:21 AM
MillerMonteSS's Avatar
2010 Monte Of The Year
It looks like Trans Go makes one for your car.
SK®4T60E-Jr
4T60E 91-99
With Modulator
Corrects: Light throttle converter shudder. Contains hardened pins and “Tuff” accumulator piston seals to reduce clutch failure due to pin and seal wear, 3rd clutch seal is self expanding. Includes PWM valve, lock-up regulator valve & bushings.
Photo-More Info
Old Mar 8, 2011 | 12:18 AM
bama_z34's Avatar
i dont know anything about transmissions yet but does that include everything i need to make my trans shift faster and harder?
Old Mar 8, 2011 | 11:34 AM
zipper's Avatar
Pretty much. The only other thing you could do is have someone tune your PCM to increase the pressure in the shift solenoids.
JaxJim
Dec 22, 2010 12:11 PM
Frosty LS1
Aug 24, 2009 02:14 PM
88ss408
Jul 24, 2009 07:44 PM
fastback4
Jun 2, 2007 07:05 AM
fastback4
May 3, 2007 03:31 AM
