Scan Tool
Old Oct 26, 2011 | 12:25 PM
aspiringthomas's Avatar
Default Scan Tool
Any suggestions for a scan tool that will do a crankshaft variation relearn. Thanks Jeff.
Old Oct 26, 2011 | 12:41 PM
z34phoenix's Avatar
i know the aeroforce gauge does it. and you end up with something great to have if your modding... vs a scanner that will sit in a box or your trunk and only used for reading codes.
Old Oct 26, 2011 | 12:48 PM
Thanks I will check it out.
Old Oct 26, 2011 | 12:53 PM
Where can you buy the aeroforce gauge. Thanks
Old Oct 26, 2011 | 01:07 PM
z34phoenix's Avatar
zzperformance.com
wbodystore.com
pfyc.com
and from their site: Aeroforce Technology Inc | Welcome
i would check all the sites for the best price. i think aeroforce's site is the highest priced!
Old Nov 3, 2011 | 09:41 PM
jasonsmith's Avatar
There are OBD II cables that hook up to your laptop via USB. So you can scan with your laptop. Though don't know which ones are good.
Old Nov 4, 2011 | 07:27 AM
SupplySgt's Avatar
You have to have software to use the OBDII to your laptop. Which is great if you know what you're doing and would like to fine tune things. I plan on getting HPtuners in the future (one of the few that support most of the V6 platforms) but that'll have to wait till I get this transmission for the truck paid for.
Old Nov 4, 2011 | 11:17 AM
jasonsmith's Avatar
Where's a good place to get the software and OBDII USB cable just to run scans with that isn't real expensive?
Old Nov 4, 2011 | 11:51 AM
to get a program that's going to run and work well you're going to be spending nearly as much as the aeroforce, if you're going to just do this one thing get the aeroforce and resell it, you'll break even or make money if you find a good deal
Old Nov 4, 2011 | 11:59 AM
jasonsmith's Avatar
I don't like it. I was wanting to try something on the laptop. I'll just try the cheap stuff on eBay.
I can get alot of info from the parts stores rent a tool scanner. But it doesn't show knock or timing retard.
Shandley
Jun 12, 2013 09:42 AM
Frosty LS1
Oct 18, 2009 08:59 AM
nugzo
Apr 27, 2009 07:22 PM
SSmokybear
Apr 25, 2008 06:13 PM
