Rocker Arm ratio
Old Jun 20, 2012 | 06:15 PM
JohnieWalker305Blue's Avatar
Default Rocker Arm ratio
what should change when you change rocker arms to 1.9 ratio
Old Jun 20, 2012 | 06:37 PM
If you want to tune the car higher than 5900RPM shifts, then you should do the springs too.
But if you are just doing rockers, you need to change the valve cover gaskets, need new rocker bolts, and that's about it
Old Jul 1, 2012 | 08:40 AM
Thanks Black
texmmt
Feb 19, 2013 03:10 PM
mairj40
Feb 9, 2012 12:02 AM
musclecarfreak1235
Jan 3, 2011 06:29 PM
BLACK ATTACK
Oct 9, 2007 11:22 AM
01whitess
Oct 7, 2005 08:22 PM
