350 turbo pan gasket #
Old Jul 3, 2012 | 12:48 PM
Carl Himmel's Avatar
Default 350 turbo pan gasket # 4th gen
I went to pepboys autozone and so on.
Im pretty sure an 83 monte came with a th350 auto. but there asking me for a part number..
Anyone know how i can help these dopes get my gasket? or am I the dope lol?
Old Jul 3, 2012 | 02:51 PM
I wont deal with autozone for that very reason....
I can go to oreilys,napa,Advanced..etc and thats never the issue...
Maybe try somewhere else for your part?
Or even call a local dealership and see what info they can give you....
Old Jul 3, 2012 | 03:20 PM
03SSLE's Avatar
The TH350 was a common choice of transmission in '83, but there were other options available. Your best bet is to ID your transmission. If it has a square oil pan with 1 corner cut off that's held on by 13 screws, the vacuum modulator is located on the right front and the code M33, M38 or M39 is stamped on the side of it then you have a TH350 transmission.
Edit: If you do find that it is a TH350 the AC Delco part is #25504700. That way they can cross reference it so you get the correct gasket.
Old Jul 3, 2012 | 05:20 PM
ok. thanks. going to pick it up
24_48Fan
Apr 2, 2010 07:19 PM
montechick
Mar 13, 2010 09:54 AM
Chevycarlo97
May 25, 2009 04:30 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
