6th Gen ('00-'05): Reversed Ignition Coils - Am I Going crazy?
Old Aug 28, 2022 | 02:21 PM
Henderson21's Avatar
Default Reversed Ignition Coils - Am I Going crazy?
Decided to do a tune up on the car.
Plugs, Coils, Wires, EGR Valve, PCV Valve, Air Filter, MAP Sensor, MAF Sensor, Thermostat and Coolant Flush.
Everything was going great. Until I got to Final Step, Putting Plug Wires back on Coils.
Every Single Diagram I can find for this car looks like this. And mine is exactly the same, Except when I went to do the 1/4 coil pack, My original OEM pack is reversed. And the wires are also reversed.
Mine Coil Pack Assembly Looks like this. I included the OEM Pack in the picture so you all could see its reversed of the diagram.
Can some shed some light onto this for me? Am i the only person on the planet who has a single reversed Coil Pack?
What arrangement should I use when reconnecting the plug wires?
Old Aug 28, 2022 | 09:38 PM
I've never played with it before, but it shouldn't make a difference which cylinder goes to which tower on a given coil. The two posts are on a combined circuit, so it fires both every time it gets energized anyways. One cylinder on every firing is just a wasted spark. The ICM isn't commanding a spark event by cylinder, its doing it by coil pack.
Old Aug 29, 2022 | 09:23 AM
I think the 1-4 coil pack is from a v6 f body. Thats why the numbers are reversed.
Old Aug 30, 2022 | 10:06 AM
carkhz316's Avatar
It shouldn't technically matter since both plugs/ cylinders fire at the same time.
Old Sep 8, 2022 | 01:41 PM
I will echo the comments, as long as the plug wires for the cylinders are going to the correct coil, it does not matter which "tower" of the cylinder they use. Both towers fire at the same time. And I have tested this before.
It could be that GM changes the numbering OR that coil is off a different car where GM used a different numbering.
teddyballgame13
Apr 30, 2014 05:37 AM
monte07
May 7, 2013 11:03 AM
Dmjr228
Oct 13, 2011 11:13 PM
roadshoptuner
FWD Tech Guides '95-'07
22
Aug 7, 2011 12:05 PM
HaRvArDaLe
Apr 8, 2007 06:14 AM
