Rev Limiter/Fuel Cutoff
Old Apr 14, 2010 | 11:06 AM
JaxJim's Avatar
Default Rev Limiter/Fuel Cutoff
I was revving the motor of my 99 Z34 in the driveway the other night and found that the engine will cut out at 4,000 rpm. (In park/neutral - not drive). Apparently the engineers installed a fuel cutoff or rev limiter to protect the engine from people like me.
I'll never forget the first time I found the a rev limiter on my 1990 Beretta GTZ. That car had a DOHC engine that redlined at somewhere around 6,500. Well the first time I hit the limiter (and not knowing the car had one), I thought I killed the motor. That thing was still pulling hard too. The GTZ was way ahead of it's time.
Old Apr 14, 2010 | 11:30 AM
You might want to stop doing that...
Old Apr 14, 2010 | 11:44 AM
MAMONTE's Avatar
Yea, they have rev limiters in park/ neutral, as well as a rev limiter in drive. Like you said, they will only rev to 4,000 RPM in park, and then they set the rev limiter in drive at redline.
Old Apr 14, 2010 | 01:21 PM
You can change it with pcm tuning. I've always thought it would be funny to set someone's drive limiter to like 2500
Old Apr 14, 2010 | 02:14 PM
hey, if they set it to 4000 in park/neutral, why can it go higher in drive?? could it be because it has something to do with the trans holding back or something?? ive never understood that??
Old Apr 14, 2010 | 02:19 PM
The computer knows what gear you are in, so the computer doesn't allow the revs to get higher in those gears.
Old Apr 14, 2010 | 02:28 PM
yeah, but i mean how will it mess up your car in park and not while its in gear?? i know there is some simple reason and i probably sound like an idiot, but its just somthing ive never understood?
Old Apr 14, 2010 | 02:34 PM
MAMONTE's Avatar
Because in park you are free reving your engine. Its different reving your engine with a load on it.
Old Apr 14, 2010 | 02:42 PM
okay, so like cause there is somthing not letting it just rev freely, alright got it. Thanks.
mrl390
Feb 7, 2009 09:48 PM
canadianmuscle427
Sep 24, 2007 11:43 PM
mlp313
Jun 7, 2007 09:27 PM
enibum
Mar 5, 2007 12:49 PM
01whitess
Oct 5, 2005 12:39 AM
