rev limiter
Old Jun 7, 2007 | 01:07 PM
mlp313's Avatar
Default rev limiter
my car 06 lt max out 107 with limiter how can i take off the govenor
Old Jun 7, 2007 | 06:21 PM
mickey's Avatar
Default RE: rev limiter
get a reprogrammer and you can take that off for ya.
but honestly 107. in the states is pretty good. i know i havent seen more then 100. here since i got it back home.
In germany it was a daily event to be over 100mph.
But the only think i can say about a programmer is try to look up somethign other then the one from Hypertech. UNLESS you want somet hing plug and play that is real simpel to use etc....
There are much better ones out there to allow you do adjust so much more.
Old Jun 7, 2007 | 09:01 PM
z34phoenix's Avatar
problem is with it being an 06 im not sure what is avalible out there yet.
and like said there isnt much reason to go faster then that. i could understand if your engine is very highly moded and your nearing that speed at the track, but i doubt you will go above 95mph in the1/4 mile.
Old Jun 7, 2007 | 09:27 PM
FlynhghR's Avatar
There's some good runs.
Do you have the 3500 engine? because my 2006 LT 3LT with the 3900 doesn't cut fuel until 113 MPH.... It actually says "Speed limited to 113 MPH" on the DIC. That's' weird, like 5 MPH is a big difference when you're going over 100 anyways... lmao. I'm just mad, because the Speedo goes to 140... That's FALSE ADVERTISING!!!!
car addict
Apr 20, 2009 11:14 PM
kweef
Dec 21, 2007 05:11 PM
canadianmuscle427
Sep 24, 2007 11:43 PM
enibum
Mar 5, 2007 12:49 PM
01whitess
Oct 5, 2005 12:39 AM
