replaced TCC (P0742) now trans wont work
Old Jul 17, 2016 | 05:24 PM
Chris Iblis's Avatar
Default replaced TCC (P0742) now trans wont work
Hey guys, hopefully someone can help, I have a 02 Monte with a 01 GTP drivetrain in it, couple weeks back it threw a TCC code, so I replaced it, I also replace the shift servo`s while I was in there. So, I put everything back together with new fluid/ filter and NOTHING WORKS!!!, not even park!! if I put it in gear the speedo works, rev the engine and the speedo will go up as if you`re driving down the street but the car will not move, the fluid level is a liter low, but I know being a liter low it`ll still move normally. if I put the car in park the tranny will make an awful noise like you were doing 50 km/h and slammed it into park, but park will not engage!? the car will roll forward in park as I found out when I put it back on the ground... I really have no idea what`s going on.
Old Jul 17, 2016 | 09:26 PM
The transmission is not my best area. But is there a reason you are leaving the fluid a liter low? I agree the car should move, but that seems like a significant amount of missing fluid.
Hopefully some of those with more experience inside these transmissions chime in.
Old Jul 17, 2016 | 11:10 PM
nitehawkjcb's Avatar
Interesting. I guess check your axles & connections to the transmission & wheels first of all... Also check the neutral safety switch... Otherwise, something that was replaced is faulty, the tranny could've gone out, could even be the shift lever.
Old Jul 18, 2016 | 05:44 PM
Because I was a liter short, that`s the only reason it`s a liter low
