Chris Iblis |
07-17-2016 05:24 PM |
replaced TCC (P0742) now trans wont work
Hey guys, hopefully someone can help, I have a 02 Monte with a 01 GTP drivetrain in it, couple weeks back it threw a TCC code, so I replaced it, I also replace the shift servo`s while I was in there. So, I put everything back together with new fluid/ filter and NOTHING WORKS!!!, not even park!! if I put it in gear the speedo works, rev the engine and the speedo will go up as if you`re driving down the street but the car will not move, the fluid level is a liter low, but I know being a liter low it`ll still move normally. if I put the car in park the tranny will make an awful noise like you were doing 50 km/h and slammed it into park, but park will not engage!? the car will roll forward in park as I found out when I put it back on the ground... I really have no idea what`s going on.
