Removing the tranny..
Old Oct 4, 2009 | 11:48 AM
OVER_REMEDY's Avatar
Default Removing the tranny..
how the hell am i suppose to get that huge thing out of there ... (96 Z34)
Old Oct 4, 2009 | 01:40 PM
RocknSS04's Avatar
You use a brace from the top to bold the engine in place, unbolt the tranny and cradle, and remove it from the bottom. Not an easy job, and 4-7 hours for a pro.
Old Oct 4, 2009 | 02:46 PM
out of the bottom? it really doesn't look like it will fit, and theres practically no room, wouldn't it be easier just to lift the motor and trans right out the top then take the transmission off while its out?
Old Oct 4, 2009 | 03:01 PM
nemesis's Avatar
2009 Monte Of The Year
pm bumpin96monte
Old Oct 4, 2009 | 06:54 PM
What he means is to drop the cradle too (the big metal square that the engine/trans bolt to)- once you drop the cradle (with the engine supported)- you can unbolt the trans and lower it out the bottom. Or you can drop the engine/trans cradle as a set too if you want to go that route.
You could also pull it out the top with the engine- that works fine too; thats how I did mine with my L67 swap just because then I didn't have to buy one of those top engine support things, and didn't have to mess with the cradle and the PS rack and such.
Old Oct 5, 2009 | 09:27 PM
yeah thats what i was thinking, i bought a parts car cause the transmission was basically done in my car, and the frame was so rusted it broke right off, all i had to do was take out the rad and stuff and the pins that hold the front part of the frame to the body i took out and the motor and all just fell right out the bottom...
Old Oct 13, 2009 | 08:10 PM
got it all fixed! replaced the tranny, took 16 hours, a lot of elbow grease, and "learning as i go" but i got it all back together, and the monte is running like new.. very happy with it all
Old Oct 13, 2009 | 08:39 PM
many congrats to your hard work, thanks for the follow-up, letting us know the great outcome! i was just curious what you were going to do, good job, see ya
peno67
Jan 6, 2015 05:02 PM
slinkeey
Feb 3, 2009 10:33 AM
KingSize
Apr 6, 2006 02:05 PM
monte97
Mar 29, 2006 05:54 PM
krazy92rs
Apr 5, 2005 04:35 AM
