remote start not working 2006
I just programmed a keyless entry on my 2006 monte carlo. The locks work, the trunk button works, but the remote start doesnt. I turned the remote start on in the information center. When i attempt to start it I can hear a click under the hood like its attempting to turn the motor over but doesnt have enough to do it. Any ideas??
Your car isn't throwing a CEL is it? Because the car will disable that feature if it is.
Another thing from my Chevy mechanic buddy. Double check all leads from the battery. Also, take a volt meter and check the red lead from the battery to ground. Do you have 12 volts?
If that checks out, take a small hammer and tap on the solenoid as someone starts the engine, if it starts the starter solenoid is bad.
Doors all locked?
Mine works intermittently. But then my car has a few minor issues - the chime dings most of the time even when the key is out and the door is open. Whenever the chime does not go off when exiting the car, it will remote start the next time.
The remote may have to be programmed specifically for the remote start aspect. It probably has the right features for the lock/unlock but maybe you NEED the tech-II scanner for the remote start?
My MC came with no remote, I bought one on eBay, programmed it through the DIC and it works when the phantom key in ignition signal is not present.
New user here i've found this forum very useful before, i'm having a problem with th remote start i press the button push all hpu hear is a click and nothing else also the lights flash when i do this. What can be the problem?
I am going through it and I have no CEL. Any other ideas?
Also, I asked this two other places and got no answer. Is the remote start module the one in the dashboard, or is it somewhere else? A Google search indicates "somewhere else," but Google is overrated.
Repair Guide: Defroster not working? Check this... 2006-2007
God_Bot
FWD Tech Guides '95-'07
Nov 14, 2019 02:57 AM
6th Gen ('00-'05): Will not start with remote starter in cold weather
DAVESS2002
Nov 20, 2014 04:22 PM
cmeadows06
Jun 18, 2009 02:44 PM
