6th Gen ('00-'05): Recent Dyno session completed, 499 whp
Old 07-28-2013, 12:35 AM
Nice Dyno slip! Why did they Dyno in 2nd gear though? They should of been dynoing in 3rd because 3rd is the 1:1 ratio in our cars.... a pull in 2nd will give a higher HP reading but a accurate reading would be a 3rd gear pull.... either wah nice numbers!!
We used the Mustang Dyno, guess this explains why Matt did the pull in 2nd gear.
As for other dynos out there (i.e. Mustang and Dyno Dynamics) - they use a load cell to measure roll force (the amount of force the tire is placing on the roller). Based on roll force and the radius arm going to the load cell, we get roll torque. Based on roll torque and roll speed, we can get vehicle horsepower. Vehicle horsepower and vehicle RPM gives vehicle torque. It doesn't matter what gear you run in on load cell style dynos as they are measuring force, not acceleration. Force does not change from gear to gear.
Jeff - the reason for the dyno in the 1:1 gear ratio is due to the Dynojet. Dynojet mathematically creates a horsepower number based on mass (which is the known weight of the rollers) and accleration (how fast the car is accelerating the known weight).
F=ma
From force (F), we can calculate horsepower.
Dyno the car in 2nd gear, and acceleration (a) goes way up, causing force (F) to go way up.
So by dynoing the car in the gear closest to the 1:1 gear ratio, we eliminate any acceleration advantage or disadvantage caused by the transmission, which gives us unskewed whp numbers (even though Dynojet has a FUDGE factor in there which makes them skewed anyways and READ high).
Old 07-28-2013, 07:23 PM
zipper's Avatar
Great numbers man, especially for your elevation. I've always admired your Monte.
Old 07-28-2013, 07:59 PM
Me too
Chev E. Chelios
03-02-2011 11:09 AM
rchurch
05-19-2009 06:49 PM
03-23-2009 12:18 PM
troutdog
02-15-2009 06:49 PM
scc24540
06-04-2007 07:49 AM
Quick Reply: 6th Gen ('00-'05): Recent Dyno session completed, 499 whp
