Problem Changing Transmission Filter
Old Dec 28, 2011 | 11:56 AM
David Price's Avatar
Default Problem Changing Transmission Filter
I have a 97 monte carlo ls in the garage at the moment
Pulled the pan and filter, there were 2 clips holding it in and now im really not sure of how to get the new transmission filter to go in tight, also with my new filter it came with a seal for the top, now there is a big plastic o ring from what it looks like where the old filter came out and im unaware as to remove it or not, i figured it was the old one so i didnt want to remove it because it looked all in tact so i just took the new ring off the filter and placed it in, it kinda wiggled around a bit but it stayed in, so i put the pan back on filled her up started the car let it run for a bit go to put it in reverse, and i got nothing, drive.. nothing so its still up pans back off and here i am, asking for a little bit of knowledge..
So what i need to know are what are those little clips for that were underneath the old filter theres 2 rods that it connects between right by the entrance where i would put the new filter, and if i have to remove that old plug or not if not should i have to be pushing very hard to get that new filter in..
Thanks a lot
Old Dec 29, 2011 | 11:22 AM
So the car is still sitting in my garage just waiting to be put back together, I called my mechanic yesterday because i was having no luck getting this filter on at all, he puts the new one in and it slides on slides off pretty easy just a little wiggling, puts the old one on, still not holding right but its tighter than the newer one. He then tells me that something isnt right either the o ring or the filter itself, to go get another filter and o ring and try to install it.. Not going to advanced auto anymore gonna try the auto zone today.
Could it possibly be that the o ring is not in fully, it looks like its sitting less than flush inside like there is a tiny little lip that might be causing the problem, any other ideas
Old Dec 29, 2011 | 01:19 PM
If it dossn't match perfectly it could be the wrong one. Iv'e bought parts and had them be in the wrong box.
Old Dec 29, 2011 | 02:52 PM
Its Finally fixed!
Took the old part back to advanced auto and went to auto zone and received a new tranny filter and o ring and gasket.
Pulled the old o ring out from advanced auto and i had to really force the new one in the hole (tapping with a rubber mallet and socket)
Put the new filter up and click, it went right in.
Bolted the pan back in added 3 quarts of fluid, and off the ramp it actually moved instead of pushing the gas and it just revving, i seriously wanted to dance, it was my first time ever doing any type of transmission work (as little as it was) so it made me happy that i saved money and did it myself.. Even though the new filter didn't help a lot of the problems that were happening but it solved some of the slipping with a little help from lucas.
Next thing is to get a new tranny for it
I think the whole problem was the o ring was to small because i could put it in there by hand compared to the new one i really had to put some effort in getting it in
Madmillz09
Dec 18, 2013 03:30 PM
GTX
Dec 11, 2013 11:03 AM
asmart82
Mar 27, 2012 09:23 AM
GREG MEDES
Dec 3, 2011 10:46 PM
slinkeey
Mar 28, 2009 11:22 PM
