Replaced 2001 Transmission filter and had an extra part when I was done
After replacing my transmission filter on my 2001 Monte Carlo LS I found in my old trans fluid some sort of orange rubber thingy with a small hole in the middle and and a slit on each end of the hole. It measures 35mm long by 10mm wide by 5 mm thick. I am wanting to know where in my transmission pan filter area this came from so I can put it back cause it looks important.
Trying to find out where this part goes
Underside of transmission with filter removed
greg.medes@med.ge.com
That looks like the coil module insulator under the 3 coil packs.. The hole in middle is where the hold down bolt goes..
I agree with ZJerry, that's EXACTLY what they thing looks like. Why was it in your trans stuff, no idea. But I think it's safe to say, it does not belong.
That's where I get all of my spare parts from that I use the next time something breaks! Can't go running off to NAPA all of the time. Gets pricey.
6th Gen ('00-'05): Had a valve lifter replaced and then...
DCMoose48
Apr 28, 2015 10:03 AM
nebstewart07
Jun 19, 2009 08:38 AM
