Is it possible..?
Is it possible..?
I have bigger plans for the monte and im already having electrical problems.. So my question is... Can an alternator work if its mounted backwards.. (pully facing the motor) basically i want to run dual alternators in my 01 LS and with a little modification.. I could mount it where the front battery is.. And weld a bracket to hold it.. I saw someone did a tripple bracket but the 3rd one went through the hood.. i dont like that but need the power boost! I heard a BI directional fan might be needed.. I plan on having my stock one rebuilt anyway so im curious if that will be needed!
Thanks!
Thanks!
Chibi i have thought about that as well.. I think i could find a way to make i work that way.. Would take more work but thats nothing new for this car..
Grizzly.. I have a 280amp xp from dc power in the stock location I need to run 2 280s... I have a hard time charging the batteries.. Plus my current amp draw is around 710 amps just in the stereo.. And the new build will be over 1000amps
You couldnt pay me to put a Capacitor in my car.. I can run full tilt in the mid 12s.. voltage wise.. But thats at arond 7100 watts.. Im swItching to 2 crescendo 3500s and 2 crescendo 1600.2s.. So a charging boost will be needed!
jessymo
02-19-2009 10:07 PM
