400-450HP possible??
Old Mar 14, 2006 | 09:17 PM
Dade652003's Avatar
Default 400-450HP possible??
Hello Ive just recently bought a 01' Monte Carlo and I want to increase it HP to at least 450HP, money is not an issue to me. So if any one has any idea of Mods that is great please reply.
Also I've installed a:
Chevrolet Monte Carlo Air Intake Systems - Weapon-R Secret Weapon
Chevrolet Monte Carlo (98-03) 3800 V6, 147156 Price:184.08
Chevrolet Monte Carlo Exhaust Systems Corsa
Chevrolet Monte Carlo (00-05) 3.8L Mid - Size Dual Exhaust w/ Single Pro-Series 4.0" Tip, 113758 Price:1,047.95
SLP 97-03 Exhaust Headers
3800 Series II W-Body Grand Prix/Regal/Monte Carlo Price: $672.95
1997-04 Header Installation Kit W-Body
Part No: 30071
Direct from THRASHER Price: $79.95
SLP High-Flow Catalitic (CAT) Converter, 97-04
Part No: 30073
Direct from THRASHER Price: $178.95
SLP Official Race Pipe, 97-04
Hypertech Power Programmer III for 01-04 (NO RETURNS)
H30030 Price:$339.95
If you have a awesome Monte Carlo, put your specs and Mods to it.
If you guys would be so kind, you can tell me what Im missing and the brand name and URL of the mods you think is great to have becuase I need to achieve around 400-450HP If possible.
Also How do you run a HP test?
Old Mar 15, 2006 | 01:47 PM
rchurch's Avatar
Default RE: 400-450HP possible??
If money is no issue, buy a Ferrarri. Or if you have to have a Chevy, get a Z-06 Corvette. It is a waste of time, energy, and money to try to get 450 HP out of a V-6. And then there is the transmission issue, the unibody to worry about, etc.....
BTW, if money is no issue, why did you buy a fairly cheap used car? Just wondering....
Old Mar 21, 2006 | 03:04 AM
00pacecar's Avatar
3800 performance.com has a turbo kit for the 3.8 that on a factory 3.8V6 will give you 280 horse and 300lbs of torque to the wheels. Hope this helps here the link below.
http://www.3800performance.com/Merch...roduct_Count=0
Old Apr 18, 2006 | 05:45 AM
CMC's Avatar
CMC
The Monte
Engine/Transaxle Performance:
ZZP Engine
-IPS CSC Supercharger Stage 4 w/Polished Novi 2000
-Air to Air Intercooler
-Vortech Bypass Valve
-50MM Blower Belt Drive
-Larger Fans
-Mototron 65lb High Impedance Injectors
-Powdercoated Fuel Rail
-Fuel Pump Voltage Booster
-Tech-Edge Alternator Re-wire
-Tech-Edge Injector Connectors
-Autolite 103 Spark Plugs
-XP Cam
-Modded Retainers
-105lb Valve Springs
-Comp Cams Hydrualic Roller Lifters
-Comp Cams Valve Locks
-Comp Cams Hi-Tech Pushrods
-L36 High Velocity Intake Insert
-L36 Stage 1 Throttle Body
-Oversized Radiator
-180 Degree Drilled Thermostat
-UD Water Pump Pulley
-OD Alternator Pulley
-ICCU Race Blue
-Hi/Low Fan Switch
ZZP Transaxle
-Trans Rebuild
-3.69 Final Drive Gears
-Input Shaft
-Solid Output Shaft
-Pump Shaft
-HD Trans Upgrade
-3800 Stall Torque Converter
-Billet Aluminum Flexplate
-34 Tooth Reluctor Wheel
The Rest
-Map Engineering Throttle Body Heat Sheild
-Optima Red Top
-MSD Coil Packs
-MSD 8.5mm Spark Plug Wires
-TOG Headers
-Random Technoligies HiFlow CAT
-Borla CAT-Back Exahaust
-Red Wire Loom in Various Areas
That's basically what it takes to achieve your goal.
And to do a HP test you get your car dynoed. Search your area for the closet dyno shop, should be one somewhere near you.
Old Apr 18, 2006 | 12:57 PM
The Black Machine 29's Avatar
how much horses you have cmc?
Old Apr 19, 2006 | 08:19 AM
z34phoenix's Avatar
there are plenty of 3800 runing 12's and some in the 9's and 10's
the best way sofar is turbo!
some are doing a SC and Turbo. but there is also a kit to throw an M90 Super charger on your 3800.
http://mymonte.com/discussion/viewtopic.php?t=13653 heavy over at mymonte.com is doing this upgrade. i would recomend doing a SC cause you already spent $$$ on exhaust and it would be sad to see you have to get a whole new exhaust system for a turbo.
i also regret seeing that you got the power programer. the DHP power tuner is the most specific tuner for our cars. but the PP should give you a good hand tuning for all that new power.
as for trany's the stock 4t65e you have is able to accept parts from the 4t65HD trany from the GTP and with other custom parts can be near bullet proof! i just saw over at clubGP that they are using a 4t65 with a FWD LS1 YES a LS1 FWD Grand Prix!
http://www.clubgp.com/newforum/tm.as...key=&language= the trany was built for 650HP but i have heard of them being built for even more.
I think ZZPerformance is the place to go for your mods if you want relyable power.
Old May 1, 2006 | 01:06 AM
85ss's Avatar
i think you shoul trade it in and get the new monte carlo that beter because first of all it is a v8 (no v6 is an ss. my opinion)and also it is rwd much beter
Old May 1, 2006 | 10:19 AM
montejass's Avatar
ORIGINAL: 85ss
The Monte SS's of today are much faster than your stock 85 SS, not to mention that CMC's Monte is pushing 400HP, oh by the way, it's also a V6.
Old May 1, 2006 | 02:15 PM
wiz kidd's Avatar
ORIGINAL: montejass
ORIGINAL: 85ss
nicely said ...oh and what does a stock supercharged ss get for quarter miles times?? just approx??
Old May 1, 2006 | 03:16 PM
montejass's Avatar
I am not too sure about the other years but I just read somewhere of a 06' SS running around 13.9 in the 1/4 with light mods. Intake and muffler upgrades.
A 2002 - 2004 3.8L NA SS runs high 15's to low 16's
