Is it possible..?
Old Sep 13, 2012 | 02:16 PM
Boxman420's Avatar
Default Is it possible..?
I have bigger plans for the monte and im already having electrical problems.. So my question is... Can an alternator work if its mounted backwards.. (pully facing the motor) basically i want to run dual alternators in my 01 LS and with a little modification.. I could mount it where the front battery is.. And weld a bracket to hold it.. I saw someone did a tripple bracket but the 3rd one went through the hood.. i dont like that but need the power boost! I heard a BI directional fan might be needed.. I plan on having my stock one rebuilt anyway so im curious if that will be needed!
Thanks!
Old Sep 13, 2012 | 02:18 PM
You would need to route the belt so it spins the pulley the correct way, I would imagine.
Old Sep 13, 2012 | 02:23 PM
Mr Grizzly Mint's Avatar
Why not just buy one big one? Some companies make giant alternators for cars with wicked sytems. Or find a interceptor version those are 120s i think.
Old Sep 13, 2012 | 02:41 PM
Boxman420's Avatar
Chibi i have thought about that as well.. I think i could find a way to make i work that way.. Would take more work but thats nothing new for this car..
Grizzly.. I have a 280amp xp from dc power in the stock location I need to run 2 280s... I have a hard time charging the batteries.. Plus my current amp draw is around 710 amps just in the stereo.. And the new build will be over 1000amps
Old Sep 13, 2012 | 03:11 PM
dang. Thats crazy huge. need a second 3800 just for your system.
Old Sep 13, 2012 | 07:28 PM
Boxman420's Avatar
Lol i wish i had a 3800 in the first place! But yes it does need two motors!
Old Sep 13, 2012 | 07:34 PM
monte07's Avatar
do you have capacitors for your stereo system as well?? i know capacitors help keep the same current flowing once they are charged with the system when you first start the engine?
Old Sep 13, 2012 | 08:33 PM
Capacitors don't do anything but drain the batteries.
Old Sep 13, 2012 | 09:20 PM
Boxman420's Avatar
You couldnt pay me to put a Capacitor in my car.. I can run full tilt in the mid 12s.. voltage wise.. But thats at arond 7100 watts.. Im swItching to 2 crescendo 3500s and 2 crescendo 1600.2s.. So a charging boost will be needed!
jessymo
Feb 19, 2009 10:07 PM
Dade652003
22
Oct 30, 2006 12:10 PM
roadshoptuner
Jul 30, 2006 09:54 AM
Dade652003
May 18, 2006 08:23 PM
Daddys Race Car
Nov 5, 2005 06:18 PM
