Ported and Polished? UIM
****y to hear that, was the TB gasket matched?, thats the only area i can't see, the intake runners deffiniatly wern't like mat said still has the cast marks in the runners, the cracks well thats no good only thing i could think of is if it's aluminum like i think is find some one who does aluminum welding and have them welded up but then you polish will need to be redone in those area's
i would most def demand atleast part of your money back, thats messed up u pay through pay pal? you may be able tp bring them into it if there is issues, don't forget about doing the LIM porting one half only gives as much as the unported half will take,
It wasn't terrible, but it was money that could have went to a real ported manifold
I'm in the process of porting my own LIM. Nothing too crazy, read no gasket matching, just smoothing and polishing the runners. Have you thought of getting an HV3 for you UIM? Gasket matching the LIM without doing the same to the heads, I have read, doesn't really improves air flow.
not to knock it more but seems kinds dull to me too
left corroded horridiably, right what i got it to
I hope you can get it taken care of quickly and without too much trouble
i highly doubt it was shined before it was sent to me, considering it doesnt seem as if it was even ported lol, it does have a nice shine to it tho
IMO that piece looks like scrap to me- I can't see that being worth the time to get it correctly fixed.
If the seller didn't tell you about the cracks up front- I'd definitely push to get your money back- the thing isn't even usable as is. I can't imagine the person wanting you to ship it back anyways- I mean its not like anyone is going to buy a severely messed up intake just for the exterior polish job.
Unless you're boosted, you're not going to have pressure in the intake manifold- its going to be in a vacuum while the engine is running. Doesn't really matter either way- its still a net pressure differential from the inside of the intake to the outside.
Also, in my opinion- if they are cracked through from the outside of the intake all the way through to the inside (like in imagine 1379- the closeup of the port)- they will leak. The other thing you must consider- it may look like its tightly pressed together now- but then you must consider what is going to happen when you torque the bolts down, and then once it goes through numerous heat cycles. I'd bet the leakage will just get worse.
Also, with those pics of the cracks near the bolt holes (like 1385)- it looks like you have less than 1/2 of the original flange thickness still intact. What's to say these things aren't going to bow and move when torqued down and heated- and possibly allow a leak through at the gasket- even with a perfectly good gasket.
As far as fixing it- they make aluminum 2 part weld putty- but it would be hard to get it into the cracks. You'd probably have to V cut them so you could assure the putty made contact with as much of the damaged area as possible. Even then, I don't think I'd be real crazy about doing this since its right next to the bolt holes- I know people have done this kinda thing before, but IMO its kindof a ghetto fix for it.
IMO, the best bet for close to the original strength and quality would be to take a die grinder, grind out the cracks- all the way down to clean metal. Then take a TIG welder, and the appropriate filler rods, and build the metal back up just above the surrounding surface. Then take out the die grinder again, and smooth it back flush with the surrounding surface. Last would be putting the intake in a milling machine to true up the outlet surfaces from the heat distortion caused by the welding.
The only thing that worries me about that would be the one that you show that goes all the way into the port. That would mean grinding a chunk out of the side of the port- and having to rebuild, and reshape that port with filler weld. Definitely wouldn't be impossible- but definitely time consuming.
However, between the labor or a person prepping and TIG'ing it, and the machining costs to get the flanges flat again- I'd bet you have more in the part than its worth. It looks to me like a stock 3400 upper intake- I can't imagine those cost that much used. I know polishing is a little steep- but IIRC I only paid like $200-250 for a whole M90 supercharger to be mirror polished. I can't imagine this costing more than $100 to mirror polish a stock one (plus shipping obviously)- there aren't that many small areas to get into, its mostly one big open area. Since this one isn't really ported much anyways- you could always just use a dremel tool and port it yourself, or send it off to get ported professionally.
theres 5 with cracks all the way through, i'm just hoping that they wont leak, i dont think there will be enough air pressure to make it worse of blow out but i'm not sure
7th Gen ('06-'07): Ported and polished throttle body for 3500
Red Monte Carlo
01-11-2015 09:23 PM
01 Monte SS
35
10-27-2013 04:26 AM
forgotten
15
01-27-2012 05:16 PM
