Ported and Polished? UIM
I just got this off of here and got it and was a little disapointed, but looking for some answers.
http://i425.photobucket.com/albums/p...h_IMG_1375.jpg http://i425.photobucket.com/albums/p...h_IMG_1376.jpg http://i425.photobucket.com/albums/p...h_IMG_1377.jpg http://i425.photobucket.com/albums/p...h_IMG_1378.jpg http://i425.photobucket.com/albums/p...h_IMG_1379.jpg http://i425.photobucket.com/albums/p...h_IMG_1385.jpg http://i425.photobucket.com/albums/p...h_IMG_1386.jpg Okay, the first thing that appears to me is that the polishing looks nice. Next, the throttle body looks stock, but on the intake manifold, it doesn't look ported, but just machined. then i noticed that there are cracks everywhere. As you can see by one picture it's cracked all the way through. Now what i want to know is how bad will this affect my car, do you think it will leak? does it look ported to you? i was told it's gasket matched, which is ported to a sense but not normal porting. Lastly, how do you think i could go about fixing this and what would i have to do? |
oh wow that sux sorry to see you get ripped off like that. did the person you got from even told you about the cracks? i don't know if it's fixable or not. go to the grand pee forums dot net and pm Reptile.
Originally Posted by silverbullitt
(Post 290562)
The crack on the middle port is the only one i could see affecting anything, only if it leaks air from there. The other cracks shouldnt make much of a difference. Ill agree those should have been pictured before it was sent though.
You cant tell if its gasket matched until you hold it up to the gasket. |
i have had ported and polished intake and also the heads. i have never got them back looking like that it looks like heat break and damage has ocered.a true porting on a intake it should have a little evedence there was water or some thing present on doing the port or present of a cleaner drops present where you could have wiped off. a true port there is always some thing used to help keep the metal cool to help disperse the heat when you do a port it creates a hotter heat then. the engine gets do to metal being shaved off and the metal gets moldeble also tends to crack when trying to rush
Originally Posted by monte07
(Post 290575)
true it looks frome one or the other the person put it on and did the damage or hapened when doing the polish
(Post 290578)
No one touched inside those ports with anything. There are still casting marks inside. If they did anything they may have ground the flanges down some maybe that opened the ports up some. I would have contacted the seller immediately after receiving that intake because of the cracks. Who wants to pay for something that is broken? I wouldnt. Who did you get that from? If they didnt disclose the cracks, I would ask for my money back and if they dont give it the best you can do is make sure everyone knows that the seller is a crook.
Originally Posted by mrl390
(Post 290608)
