Popping noise when braking
Old Aug 15, 2010 | 02:41 AM
Tavi07SS's Avatar
Default Popping noise when braking
Hello all, I have an 07 monte ss and when I brake i hear a poping noise on the front drivers side I can even feel it through the floor....any ideas as to what the problem might be? I recently replaced the brake pads with ceramics.. and the rotors looked fine...no indicators on the gauges either. Thanks for your help in advance.
Old Aug 15, 2010 | 05:47 AM
Did you do the correct "break In" procedure?? Also, I would check the whole HUB assembly, it sounds like somthing could be loose. But most likely, the new pads you switched to, what kind are they?
Old Aug 15, 2010 | 02:24 PM
Tavi07SS's Avatar
Well actually the pads are about 4 months old....the popping has only just recently happened.
Old Aug 15, 2010 | 07:29 PM
04 dale jr supercharged's Avatar
what type of grease did u use brother if u didnt use any hi temp grease there will be a problem take off brakes re grease and go from there
Old Aug 16, 2010 | 12:20 AM
Tavi07SS's Avatar
10-4...Ill do that as soon as i have some free time....as well as check the HUB asby.
SanJoseSS
Nov 1, 2015 10:31 PM
Malcolm Fay
Feb 17, 2015 04:25 PM
billyb
Jan 25, 2015 10:57 AM
Brad Lee Hobbs
Oct 25, 2014 08:41 AM
MonteLSV6
Aug 22, 2013 01:39 PM
