plug in scanner. DONT WORK.. HELP
Old Apr 21, 2012 | 07:42 AM
03SSLE's Avatar
Originally Posted by gtpshawty
ok cool.. one more thing.... while im on it.. my bro has the car in okl so i cant check it right now... but his wheel hub making a ****ty sould like something engadging and getting stuck... from the drivers side... and the abs light shoot on and stays on also traction device messing up too all can be caused by bcm?
Those symptoms are indicative of a bad wheel bearing. The hub assembly will need to be replaced.
Back to the OBD II problem...
Are you getting power to pin 16 of the plug? It is the pin in the lower right corner of the plug as you're looking at it. Backprobe that pin with a test light or meter and make sure it is hot.
Here's a schematic and pin assignment for the plug:
General Motors (GM) OBD II diagnostic interface pinout and wiring @ pinoutsguide.com
Old Apr 21, 2012 | 09:26 AM
gtpshawty's Avatar
i never used a test light on it.. but will when i get the car back.... and i thought the wheel bearing.. but it does it every once in a while... and i figured it would do it all the time if it was the bearing
Old Apr 21, 2012 | 11:10 AM
MONTE2000SS's Avatar
check the brake fluid also when your break fluid is low it will through a abs light
Old Apr 21, 2012 | 01:18 PM
03SSLE's Avatar
The ABS and traction light both coming on are classic signs of a bad wheel bearing on these vehicles. That's where I would focus my attention.
Old Apr 27, 2012 | 08:34 PM
gtpshawty's Avatar
will do when i get the car back to me
Old May 16, 2012 | 01:47 PM
gtpshawty's Avatar
all wheel bearings check out good.. just tested em
Old May 18, 2012 | 12:50 PM
Bait's Avatar
I replaced my wheel bearing but still reading bad????
Old May 25, 2012 | 07:49 PM
aussiek2000's Avatar
And how exactly did you test them?
mwjames
Mar 1, 2012 04:23 AM
Cowboy6622
Feb 6, 2012 10:56 AM
jeffsmonte
Mar 9, 2009 04:07 AM
RickCoMatic
Feb 19, 2008 08:01 AM
BeachBumMike
Aug 15, 2007 07:06 PM
