plug in scanner. DONT WORK.. HELP
Old Feb 21, 2012 | 07:13 PM
gtpshawty's Avatar
Default plug in scanner. DONT WORK.. HELP
2003 monte carlo ss... check engine light is on.. and lifters are ticking.. i plug up my scanner.. says no link found.. so im guessing the data link isint working... i checked the cig and aux fuse.. all were good.. still no data link... please helpp
Old Feb 21, 2012 | 09:57 PM
bearbear3_4's Avatar
Is it an OBD 2 scanner?
Old Feb 22, 2012 | 08:11 AM
Have another car to check whether it's the car or the scanner?
Old Feb 22, 2012 | 11:24 AM
gtpshawty's Avatar
yes its an odbII and i hooked it up in the gtp it worked... tried it in the mc it says no link
Old Feb 22, 2012 | 11:33 AM
Only thing I could think of is checking different fuses?
Old Feb 23, 2012 | 07:16 AM
03SSLE's Avatar
The driver side fuse panel contains a fuse marked CLST/BCM that supplies power to the data link. Have you checked it?
Old Feb 27, 2012 | 10:15 AM
gtpshawty's Avatar
nope.. thankx.. didnt even know it was a fuse block over there
Old Feb 27, 2012 | 06:04 PM
gtpshawty's Avatar
checked every fuse in the car they all are good
Old Mar 13, 2012 | 08:48 PM
Duderino's Avatar
most standard scanners for sale to public scan engine codes and extra for abs,,Pcodes,,the genysis scanner is the one to use
Old Mar 20, 2012 | 04:00 PM
gtpshawty's Avatar
still having this problem.. what else could it be...
