PCM help
Old Jun 5, 2011 | 11:54 AM
lade03SS's Avatar
Default PCM help
So I got my intake, plugs, tsat, and downpie on, and now I'm throwing 2 codes from my PCM
C1298- PCM class 2 serial dadt link malfunction
C1277 requested torque signal CKT malfunction
What would cause these codes to pop up all of a sudden when i cleaned the PCM and was sure to put the pcm back together the way it came out... Any Ideas on what to look for/do?
Old Jun 5, 2011 | 03:29 PM
zipper's Avatar
What Tstat did you install and why did you remove the PCM?
The only info I could really find was on the C1298 code: diagnostic repair for chassis codes C1254 and C1298 on ... - JustAnswer
Old Jun 5, 2011 | 05:13 PM
lade03SS's Avatar
I installed the 180* SLP thermostat, and I had to remove the old pcm to install the new mounting tray for the CAI. I had the shop I go to run the codes and thats what the code reader said that the designations meant. do you think it could just be a bad ground, or a dirty pcm connection?
Old Jun 5, 2011 | 06:54 PM
zipper's Avatar
It sounds like it has something to do with the PCM's connection. Double check that, clear the codes, and then see what happens.
The_Maniac
Nov 10, 2010 09:42 AM
Blazed SS
27
Jul 29, 2010 08:03 AM
sprfrk2005
Jan 26, 2009 12:03 PM
MonteCo SS
May 23, 2008 09:58 PM
White05LT
Oct 7, 2007 09:25 PM
