quick pcm help
Old Jul 15, 2010 | 09:38 AM
Blazed SS's Avatar
IT HERTZ
Default quick pcm help
does this look right for my car ? I just want to make sure before I order it
ZZP 1.0 PCM
(In Stock) ZZP 1.0 PCM - $99.99 Year of your car
2001 2002 2003 2004 2005 (+ $20.00) Model
Monte Carlo (not supercharged) \
Core chargeprepaid return label (+ $85.00) )
Option 1 none
Option 2 stock
Option 3stock
Option 4 0420, EGR, EVAP code deletes (+ $20.00)
Old Jul 15, 2010 | 09:46 AM
Montelicious's Avatar
I just got the basic V.1 canned tune from 3800 performance but didn't get the extra stuff you got. However I may need to in the future. I have a year and a half till inspection here in NJ....who knows
Old Jul 15, 2010 | 09:49 AM
Blazed SS's Avatar
IT HERTZ
cool I just did not know about the Option 4 0420, EGR, EVAP code deletes (+ $20.00)
or they have Option 4 0420 code deletes (+10.00)
Old Jul 15, 2010 | 09:52 AM
I wish I could help you with that. I am sure someone here will answer that for you quick...
Old Jul 15, 2010 | 09:57 AM
I would just get the P0420, you aren't deleting your EVAP system.
Also, do you plan on modifying any of the car at anytime soon? Downpipe, Rockers, HV3, anything??
If so I would wait for the PCM.
Old Jul 15, 2010 | 09:59 AM
I knew it would be Mod Mike to reply first! Great to have such knowledge around!
Old Jul 15, 2010 | 10:01 AM
Blazed SS's Avatar
IT HERTZ
I do not plan on doing any more mods to it this year although I am thinking that I may put on a supercharger at some point of owning the car
Old Jul 15, 2010 | 10:02 AM
It's also good to know if your EGR system gets clogged up or stops functioning well
If you are gonna supercharge, then you'll need a new PCM for that anyway, so you'd be sending it in. IF you really want a PCM, then you are fine with those options (minus the EGR/EVAP)
Old Jul 15, 2010 | 10:13 AM
Blazed SS's Avatar
IT HERTZ
sweet thank you man the 0420 code is killing me i got a scanner just to delete it when it comes up but that is the biggest reason i am getting the pcm every thing else it does is a bonus at this point
Old Jul 15, 2010 | 10:16 AM
Do you have a downpipe??
