P0121 and P0122, I hate Codes!
Hello again Everyone. I guess this is my week for questions.
I have codes P0121 and P0121. Both refer to a week signal from the TPS. I have replaced the TPS twice and I still get the same code. So I believe that the signal wire is broken or frayed. I've tested the 5v and ground lines and the are Both fine. Reed 5v with the key in the on position. I was also able to read the resistance change from the each of the outer pins on all 3 TPS to the center pin. So that points me to signal wire. But without removing the whole harness from the PCM, I can not test that wire and even if I do, if there is one good strand of wire, then it will read as 0 ohms on the multimeter. So how should, do I test this wire to find the brake? There is only about 4" of actual exposed wire before it goes into the Harness leading to the PCM.
Symptom: when driving in a parking lot or Very heave traffic, if I Tap the gas and then release it, the idle drops to about 300 RPMs then pops back up to 700 to 900 RPMs. Sometimes, if I tap it light enough, the motor shuts off. There is Also a sulfur smell But only when I am Hard on the gas. I need new ideas!
Thanks
Thanks
I looked the two codes up in the shop book. An interesting note I saw on code P0121 was this:
PM me your e-mail address, I can send you the actual GM shop manual data for those codes.
A skewed MAP signal--A skewed MAP signal may cause the PCM to incorrectly determine the TP sensor is out of range. Inspect for an unusually low or high MAP reading.
JC Colon
Nov 26, 2012 09:52 AM
Franks 03SS
Sep 2, 2011 09:02 PM
