Over bored 4.3 1985, performance cooling options?
Old Feb 14, 2022 | 05:55 AM
arlowf's Avatar
Default Over bored 4.3 1985, performance cooling options?
So I have a 4.3 that apparently was bored over (confirmed) .060.
The main issue with that is apparently heat; if I can keep it all cold it'll run smooth and last longer.
What can I get to cool my engine heads/pistons more than stock?
I'm getting the engage swapped in 60 days. But I need it to not blow on me before then. I was hoping to get some tips like oil weight, or some bolt on, or some trick to keep cylinder walls from over heating until then. I know nothing about bored cylinder head stability other than people have done this and gotten away with it without issues. I didn't do it, I bought it like this.
So a performance radiator? How about an intercooler? I'm suggesting those two things because they would survive across engine swaps.
Old Feb 15, 2022 | 03:32 PM
Jeffs02rwdSS's Avatar
Getting a radiator for a G Body with a 5.7 diesel would be a easy bolt on as it uses all the factory mounting. A properly work fan and shroud and thermostat should be more than efficient on that engine. Having a engine that's bored oversize with a stock cooling system really shouldn't have a problem.
Old Jul 4, 2022 | 10:58 AM
koladx's Avatar
The first plan of the little block remained amazingly unaltered for its creation run, which started in 1955 and finished, in traveler vehicles, in 2003.
Tutuapp 9Apps Showbox
BeachBumMike
13
May 18, 2016 08:29 AM
May 21, 2014 04:50 AM
tweek
Nov 4, 2013 11:18 AM
Oct 21, 2012 04:18 PM
Gib DTD
Aug 28, 2009 11:35 AM
