6th Gen ('00-'05): oil question
Old Mar 6, 2015 | 05:03 PM
droppeddreamer's Avatar
Default oil question
I have a 2000 model monte Carlo with a v6 not the ss version. I changed the oil in it the other day becausee for one it needed it and two because I just got the car. .. well after having it on the lift I could hear a noise coming from the oil pan. No check engine light is on. Could it be the pump or the oil pressure sensor?
Old Mar 6, 2015 | 05:27 PM
I don't know the answer to your question but welcome to the forum!!
Old Mar 6, 2015 | 06:23 PM
03SSLE's Avatar
The oil sensor wouldn't make any noise. If it's a knocking sound a connecting rod may have spun a bearing. The seller may have put a thicker viscosity oil in the engine to mask it so they could sell the car. Now that the proper viscosity oil is in the engine the noise is apparent. If it is a whirling/grinding sound it may be the pump, but they usually seize up when they fail and don't make noise.
Old Mar 6, 2015 | 07:55 PM
turbo monte's Avatar
I 2nd what 03ssle said.
Old Mar 7, 2015 | 10:56 AM
Default reply
It's not a knocking sound it's more like a grinding ? Sound
mstrmysterious63
Sep 25, 2012 03:04 PM
Randy Biron
Jul 14, 2012 08:07 PM
crete
Nov 6, 2011 07:05 PM
70monte1
25
Jan 19, 2010 09:04 PM
brando1083
Nov 15, 2007 10:12 PM
