Oil pan gasket.
Old Feb 7, 2014 | 05:01 AM
ecosta221's Avatar
Default Oil pan gasket.
Alright so im replacing my rear main seal and a couple other things while its there really soon and my oil pan looks like its leaking too. The gasket is metal so should i even change it or just put some new sealant on the old one? Also what seal would be between the engine and the trans? My parts manager cant find one on the diagram but my dad thinks there might be a seal there. Any ideas what i could be?
Old Feb 7, 2014 | 09:39 AM
03SSLE's Avatar
With all the work you're putting into the vehicle why chance a leak by reusing the old gasket? Buy a new one. Torque the bolts in the correct sequence and don't over tighten them. If you do there's a good chance the new gasket will leak.
Old Feb 8, 2014 | 08:22 AM
turbo monte's Avatar
Agree if its leaking why reuse that gasket buy a new one. As said by 03ssle torque in correct and to correct spec. Also if you have a 3800 there is no gasket between engine and trans. I'm not sure about the 3400 but I don't think it does either.
24_48Fan
Apr 2, 2010 07:19 PM
montechick
Mar 13, 2010 09:54 AM
Chevycarlo97
May 25, 2009 04:30 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
