octan update
Old Feb 9, 2010 | 12:11 PM
Default octan update
ok, i been filling up with the 87 and like everyone said it didnt make no difference. but, im still having the drop in power. i found if i dont slam the gas down in the low end i keep the power in the higher rpms. you think its time for new plugs, wires? just hit 104k
Old Feb 9, 2010 | 12:45 PM
Wait what?
If you are referencing an older thread can you link to it, or update that thread??
Old Feb 9, 2010 | 09:43 PM
I'm also confused what you're talking about here- but it sounds like you're having driveability issues. However, it is going to be tough to diagnose problems online without being able to look at some scan data to see what is actually going wrong- have you had anybody scan the car while it is having the problem?
Have you been doing regular maintenance as specificed in the manual? Just throwing parts at a problem until you find the solution is a bad idea. If you've been following proper maintenance, you should've changed your plugs at 100k right?
Old Feb 10, 2010 | 07:49 AM
MAMONTE's Avatar
I remember his old thread.
I would say that if you have never replaced your plugs and wires, thats a good place to start, because you are already a little over due. It could help your problem, but I would not bet money on it. It simply COULD help, and is a maintenance thing that really should be done if you've never done it.
Jan 19, 2010 02:43 PM
BeachBumMike
Nov 30, 2007 04:59 PM
z34phoenix
Feb 18, 2007 03:23 AM
BeachBumMike
Jan 31, 2007 02:22 PM
AFAN4_29
Jan 4, 2007 12:13 AM
