nos
It's not terribly hard to install. A lot of people put a throttle body spacer to put the tap.
50-100 wet shots I believe are the best bet on these cars.
The downside is that you need to tune for the nos, so when you aren't using it you will be much slower than you are right now. Also, you have to refill the damn bottle all the time. (and the transmissions aren't that strong for these bursts)
Save yourself some trouble and save up and go turbo
TripleEdgePerformance.com is a good read on the 4t65-e (and a great place to buy BUILT transmissions)
cartuningperformance.ca
