nos
so does anyone here run now on any of there cars whats it like and how hard was it to put in and what r the ups and downs
It's not terribly hard to install. A lot of people put a throttle body spacer to put the tap.
50-100 wet shots I believe are the best bet on these cars. The downside is that you need to tune for the nos, so when you aren't using it you will be much slower than you are right now. Also, you have to refill the damn bottle all the time. (and the transmissions aren't that strong for these bursts) Save yourself some trouble and save up and go turbo ;) |
how would a basic turbo kit run for an 04 monte and what else would i need
let me no how that works out and if i did this will the trans be able to handle it
Originally Posted by mikemollic
(Post 415692)
TripleEdgePerformance.com is a good read on the 4t65-e (and a great place to buy BUILT transmissions) |
ok ill check it out thx
(Post 415686)
cartuningperformance.ca |
