newbie motor swap question on a 97 Monty
Old 02-19-2008, 03:13 PM
mrl390's Avatar
Default RE: newbie motor swap question on a 97 Monty
ORIGINAL: wally
Also thanks for the susp advice...what about just ordering stock 99 Z34 replacementstruts new from Napa?
Its all a matter of what you want to spend. The napa replacements are probably just fine. You will also see a big difference in handling when you upgrade the sway bar. The front onemay only be a little bit bigger, but it will make a difference. Make sure you upgrade brakes too. You are gonna need all the stopping power you can get once you get the swap done. Lol.
  #32
Old 02-19-2008, 04:05 PM
So would the above 3 items work well in combination together. I'm thinking they're the most cost effective.
Yes, definitely. If it weren't going in a 5th gen monte, I'd say pick up a set of pacesetter headers for ~$300 or so instead of the powerlog, but with how crappy it is to do headers in a 5th gen, it would make them more work than you'll probably want to get into.
I know he doesn't want to go nuts building this thing, but he'd like more power for sure.
With those mods the thing should run 13s all day long, it should be plenty quick for a street car.
I've got a 12 ton press so the pulley seems like an obvious choice.
I dunno- just be careful you aren't using a jaw puller to get the old one off. They have a pulley removal/install tool that makes it pretty easy at zzp. I've just seen a lot of people damage pullies and snouts getting them on off.
Where can i get these 1.9:1 rockers at?
http://www.zzperformance.com/grand_p...&catid=104
Thats new, used ones pop up all the time on CGP for $200-250 depending on mileage.
You could do that, or something like some KYB GR2s, dunno what the price difference would be.
  #33
Old 02-20-2008, 05:25 PM
wally's Avatar
OK, another question, i'm finding a LOT of good deals on buick park avenue, buick riveraand buick regal motors from 97-00, but very few on the pontiac grand prix. Are the motor mounts different on these, what other issues am i going to be dealing with if i go with one of these l67 motors vs the grand prix...thanks again for your help everyone!!!
  #34
Old 02-21-2008, 05:36 PM
You have to watch the H-bodys because there are some minor differences in the mounting as well as other things. The upside is that they tend to be less likely to be beat on. Since you're replacing all the engine harnesses anyways, and the basic engine is the same- I imagine it wouldn't be too much worse to switch over some mounts. You'd probably be better off with a gtp pcm though, as some of the people I've seen swap buick L67s run into problems with the factory antitheft.
  #35
Old 02-21-2008, 06:20 PM
GrandPaDave's Avatar
Not to hi-jack, but this thread has been a great read.
We have really added some extremely knowledgeable members in the last 12 months.
I love this reading this exact kind of chat. Keep up the good work everyone.
  #36
Old 02-22-2008, 08:57 AM
wally's Avatar
ORIGINAL: bumpin96monte
You have to watch the H-bodys because there are some minor differences in the mounting as well as other things.... as some of the people I've seen swap buick L67s run into problems with the factory antitheft.
Good call, i'll keep hunting for the grand prix. I'll keep you all posted and maybe do a write up as we do the swap at the end of march
Monte carol
05-18-2015 05:08 PM
ttmillus2
07-05-2011 10:28 AM
thefuzz
06-28-2011 09:50 PM
kyle
09-15-2008 11:54 AM
OZONEDDDDD
10-11-2005 06:30 PM
Quick Reply: newbie motor swap question on a 97 Monty
