NEWBIE HELP!!!!!!!!
Old Nov 25, 2007 | 04:52 PM
msbee0107's Avatar
Default NEWBIE HELP!!!!!!!!
O.k guys I am a newbie at the car thing and am trying to help my husband rebuild an 86 ss. So for christmas I am looking at buying him a carburetor because the one he has in right now is the orginial and yeah it needs to be replace have any ideas where I can go to get one or what kind all info is greatly appreciated! And one other question.... any ideas about this it has a leak on the pass. side so when it rains it goes down behind the stereo area and on the pass. side I heard it could be the firewall or the windshield any suggestions where I should take it to get it fixed. THANK ALOT IN ADVANCE
Old Nov 25, 2007 | 05:30 PM
Cowboy6622's Avatar
Default RE: NEWBIE HELP!!!!!!!!
the leak is probably because the rubber trim has dry rotted around the windows, you could probably buy some replacement for him. as for the carburetor, i like the holley's. the formula for a carburetor, i believe, is the maximum rpm's the engine will run x the cubic inch displacemnet (CID) of the engine divided by some number like 3456, or something like taht. theres 4 numbers, and they go in order. somebody on here probably knows it.
Old Nov 25, 2007 | 05:43 PM
TrickRacin's Avatar
For a carb it depends on what he plans on doing with the car. If it going to be more of a street cruiser I would go with a 600-700 CFm vac secondary holley. If it is gonna see alot of strip time I would look more towards a double pumper.
and the formulas
STREET CARB. CFM = RPM X DISPLACEMENT ÷ 3456 X .85
RACING CARB. CFM = RPM X DISPLACEMENT ÷ 3456 X 1.10
RPM being max RPM ie: 5500
Old Nov 25, 2007 | 06:09 PM
msbee0107's Avatar
ok where would I find the info and what does all of that mean. I am sorry I am just starting out and want to learn as much as possibly so I am not just in the way when it comes to it you know.
Old Nov 25, 2007 | 06:26 PM
88ss408's Avatar
for your carb if you have all ecu stuff disconected i would go with a 600cfm edelbrock but if you still have all the ecu running condition your stuck with the ccc Q-jet unless you want to change the distributor to a vacume advance unit
Old Nov 25, 2007 | 07:36 PM
msbee0107's Avatar
Okay what does all of that mean??
Old Nov 26, 2007 | 06:17 PM
TrickRacin's Avatar
ORIGINAL: msbee0107
The RPM for this formula is the max RPM the engine will run. If it is still stock I would say 5500
The Displacement is the cubic inches of the engine, If it is stock it is probably a 305 ci or a 5.0 liter
so CFM=5500 X 305 ÷ 3456 X 0.85
so basically a 413 CFM carb. So a vacuum secandary 600 would be more than enough for what ya need unless like asked, if the factory computer control is all still hooked up you will need to change the distributor also to go to a better aftermarket carb.
Old Nov 26, 2007 | 07:05 PM
Cowboy6622's Avatar
the.85 is how efficient hte engine is... that means it creates 85% of the power the goes into it... it is 85% efficient.....
Old Nov 26, 2007 | 08:39 PM
Chucks88SS's Avatar
The leak is the ac box on the pass. side fire wall. in the engine bay. it drys out and needs to be replaced.
Go here:
www.montecarloss.com
this place has EVERYTHING youll need to know about 4th gen montes, i know these people and they are nothing but help at all levels.
Old Dec 1, 2007 | 07:10 PM
04 Intimidator's Avatar
By far the 600 cfm Edelbrock is the way to go!
contra2443
Jan 17, 2011 01:54 PM
MrsMonteSS
Nov 15, 2010 10:58 PM
benh911f
Aug 17, 2010 11:11 AM
Monte
Nov 8, 2007 07:18 PM
MING THE MERCILESS
May 31, 2007 08:31 PM
