New Question, for me anyways
Old Sep 19, 2013 | 02:02 PM
JC Colon's Avatar
Default New Question, for me anyways
Hi MCF,
On my way to work this morning I noticed some Steam coming from between my Hood and Windshield on the passenger side in the corner. Not much, like the amount of smoke coming from a lit cigarette. I pulled over and checked it. Saw nothing. Started driving again and saw it again. I have Also been loosing coolant. So I suspect one of the coolant elbows. So I went on EBay, But all I was able to find was the Plastic set for $16, that I've Reed here are a GM weak spot.
My question is, where do I go to get a set that are better than the OEM. I don't want ti have to replace them twice! Thanks guys and I Hope you all are having a good day!
Old Sep 19, 2013 | 02:50 PM
You should be fine replacing them with the plastic, but $16 is a lot. You can buy them for $5 at almost any auto parts store in the Self Help section.
ZZP sells the aluminum: - Aluminum Coolant Elbows #ZZ-ALCE
Also if you can find them elsewhere they are Dorman Part # 47065hp
Old Sep 19, 2013 | 05:31 PM
JC Colon's Avatar
Hi Mike, Thanks for the info. I'll Look for them this week end. If only my other problems were so easy/inexpensive to fix.
Old Sep 20, 2013 | 08:13 AM
It doesn't matter how you get there, it just matters the outcome
Good luck with everything in life
Old Sep 20, 2013 | 09:57 AM
JC Colon's Avatar
I know. Just wish I had the funds ti fix all my woes at Once. Would be nice to drive my baby like she was went to be driven!
Old Sep 20, 2013 | 12:55 PM
Dorman makes the aluminum elbows. I see the aluminum and the plastic ones in all the auto parts stores in the Dorman isle. FYI - Dorman has had a history of using an o-ring on some plastic elbows that was too thin, causing the elbow to push out (I had it happen to me once, before the aluminum elbows, so I went and bought $30 genuine GM).
I can tell you, based on the castings, the genuine GM and Dorman are different elbows (and so far, the GM has not backed out).
Old Sep 20, 2013 | 08:35 PM
A05C's Avatar
I just got a set of aluminum ones from Autozone for 12$ or something like that.
The same Doorman part number as listed above
rj
Feb 21, 2011 06:05 PM
Super Strong SS
Mar 22, 2010 10:49 PM
Budsjlm
Jul 21, 2009 09:44 PM
