7th Gen ('06-'07): Need help!!!!!
Old Nov 20, 2012 | 03:53 PM
monte06ltz's Avatar
Default Need help!!!!!
so i have a 2006 monte and its dripping coolent it looks to me to be running down the side of the fan or could be comming from the hose that runs to the radiator its not a lot of coolent but i can see a few drips on th drive way could it be the radiator this soon? i dont know if anyone els has had the same problem with their 06
Old Nov 20, 2012 | 03:54 PM
monte06ltz's Avatar
o and its got 126,000 on it
Old Nov 20, 2012 | 07:32 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
I had the water pump go out on mine. It would only leak while it was running and it would leak behind the pulley where you couldn't see it. The belt caused the coolant to mist onto my radiator and that was where I thought the leak was coming from. It was pretty easy to change the pump. I wouldn't want to do my rad though.
Old Nov 21, 2012 | 12:29 PM
monte06ltz's Avatar
maybe it could be the water pump idk how could i tell if it was the water pump it only drips when its on but i cant fined wer its leaking at
Old Nov 21, 2012 | 12:31 PM
The only way that I could tell was because I was looking at it with a flashlight at night. That's what let me see the tiny water droplets being thrown onto the radiator. I wasn't even overheating, the only indicator was the droplets.
Old Nov 21, 2012 | 12:46 PM
monte06ltz's Avatar
ill probley just replace it and see if it stops it cause its only a $60 part at autozone but ill try to get a pic of it if i can get it a good one
Old Nov 21, 2012 | 12:47 PM
monte06ltz's Avatar
MillerMonteSS thanks for your help!!!!! im going to take it friday and have it looked at and maybe they can see something i dont
Old Nov 21, 2012 | 06:02 PM
monte07's Avatar
the best thing is do a pressure test to see if it holds pressure. if you go to all the hoses and then check the pump and radiator. i ended up finding out my pump went on my 3.5 as well as the uper radiator hose. fixed them both. i did the pressure test twice do to making sure i fixed the leak. also to find out if there is no other leak while i was under the hood. helped when i was trying to get all the air out as well.
Old Nov 26, 2012 | 08:23 AM
MAMONTE's Avatar
The water pump is a strong possibility. My 3.5L needed a new water pump at approx 65K. I'm now at 165K with no more water pump issues, but I think it's pretty common on the 06-07's to have a water pump fail early in life.
Old Nov 26, 2012 | 09:27 PM
monte07's Avatar
i am still wondering why the pumps break early in the engine life. i had my truck mustang mt dads cougar he gave me wear out. with a lot more miles on them.
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
zk6216
Mar 11, 2008 11:19 PM
mickey
Aug 23, 2006 05:31 PM
