6th Gen ('00-'05): Need to clarify some tranny issues...
Ok...the symptoms I'm getting is the same thing I always have with all my 3800's. I was wondering if this is 'normal' with these transmissions. When I hit around 40-55 the RPMs drop gradually into gear & I feel like I'm stuck in some sort of rut & it won't drive out of it unless I accelerate hard or let go of the pedal, let it shift down & go again. BUT, If I'm gradually accelerating up to 60-75mph I never get stuck. Its only when I steady out to 40-55mph.
Most of my driving varies around those speeds so I get it often. Alot of times I will shift into the 3rd selection because it drives easier. (avoiding the overdrive) I was wondering if this is something that is supposed to happen..
To be honest, I don't think the fluid has ever been changed. I'm around 65k right now. It does not smell burnt or horrific just smells worn, & on a tissue it still shows a little pink. I was wondering if doing a tranny service will help but at the same time with 65k, I'm scared I'll blow the transmission.. If I were to flush the fluid I'm probably going to save atleast a quart (or maybe two) of the old fluid, then add fresh fluid + lucas tranny fix to give it a boost.
Sounds like mine. And its not od. I think its the torque converter locking up or unlocking. Which ever it.does. Drives me crazy. End up at like 1500rpm going up.hill. 40-45mph
Don't flush it only do a filter change. What u are feeling is the torque converter locking up. This is normal to a point, this keeps the trans cooler and saves gas. If its real bad the converter could be going bad or possibly a sensor of some sort....
Looking up prices for one just in case & it isn't too crazy, I'm obviously assuming if I was to swap out the torque converter, I'd have to drop the transmission. would it just be a better idea to get a new transmission instead? (since its at 65k on what I believe is original fluid.)
It doesn't really sound to me like your transmission is bad. Just the torque converter locking up at the normal speeds it does. I would suggest a pan drop and filter change like other have mentioned, because it's certainly due for a fluid change.
I bought my car at 87,800 miles from the original owner and I don't think the tranny fluid had ever been changed judging by the look of the fluid. I dropped the pan, changed the filter and filled it back up. I highly doubt your tranny is bad at 65,000 miles unless it was abused. Doing a fluid and filter change is a lot less expensive than replacing a converter or tranny. Do this first and then determine if something else could be wrong.
Wayne
Wayne
Wayne
Wayne
The filter pulls out of it's hole but on mine I had to use a little bit of force to get it out and to re-install it. There is a replacable metal piece with a built in rubber gasket that goes up in the hole that is usually included in the filter kits. I usually don't replace this unless the rubber gasket is messed up. This piece is sometimes hard to get out and you have to be careful if you do take it out so you don't mess up the aluminum bore it sits in. To get these out, I usually take a small flathead screwdriver and carefully pry a section of the metal piece away from the bore it sits in and then use a pair of needle nose pliers to pull the rest of the piece out. It's really not as hard as it sounds.
Wayne
