motor mounts
Old Dec 1, 2014 | 04:44 AM
barcasmith's Avatar
Default motor mounts
Can someone send me a link for an 85 monte ss motor mount R&R? I'm doing a 383 swap with solid mounts but i cant get to the lower nuts to the bolts, seems like impossible lol thnks
Old Dec 1, 2014 | 11:51 AM
I don't believe theres going to be an issue..The mounting points should be the same...
I'm guessing it has a 305 now?
There both the same block... just different outputs/HP's.. If i'm not mistaken.
If there is a difference..you may end up changing the old frame mounts and or having to weld/bolting in new frame mounts..
Mota1983
Aug 16, 2013 06:46 PM
mavrickf1613
May 22, 2009 01:46 AM
2000_BLACK_SS
Mar 15, 2008 09:21 PM
ExplosiveSoundz
Dec 1, 2007 04:06 PM
Hoosierdaddy
May 9, 2007 12:50 AM
