missing connection
Old Mar 7, 2010 | 09:23 PM
jdq's Avatar
jdq
Default missing connection
2001 MC ss
Hi I just did lim/uim gaskets on my daughters Monte and after finishing up I have 1 electrical connector I dont know where it goes.
It is grouped with the alternator ground and alternator electrical connection, there is nothing to connect it to there.It is only about 3 inch long wires from the harness so the connector cant be far but nothing there but alternator.Could it be for adding something.It is twice the size of the alternator hook up and is creme colored with orange rubber seal, thanks.
Old Mar 7, 2010 | 11:34 PM
Sliver's Avatar
Can you post a picture?
Old Mar 8, 2010 | 12:29 AM
nitehawkjcb's Avatar
It may be for the MAP sensor.
Old Mar 8, 2010 | 08:54 AM
If I recall correctly that was just an extra connection. Probably used in a different vehicle with the 3.8
Old Mar 8, 2010 | 09:57 AM
MAMONTE's Avatar
Another member on this forum had the same problem, if its the same connector i'm thinking it is, we came to the conclusion that the Monte did not use it, and it was supposed to be a free wire on the Monte. I checked on my mom's bonneville with the 3.8L, and found the wire/ plug used, and the place it was used at DID NOT exist in the Monte.
Old Mar 8, 2010 | 10:15 AM
jdq's Avatar
jdq
Awesome thanks guys
Old Mar 9, 2010 | 02:13 PM
jdq's Avatar
jdq
Just to recap alt is pooched.There is 2 connectors there becausethe larger one is for the monte alt, other small one is the same one for my bonny alt.So 2 different alternator connections.Thanks Possibly 105 amp and 125 amp
04MonteLS
Jun 27, 2013 06:42 AM
reelez
Feb 14, 2011 11:16 AM
kevtheo1191
Jan 26, 2011 08:13 AM
jibb3r
Aug 3, 2009 05:22 PM
96_z34
May 17, 2006 10:45 PM
