Misfire 4
How did you validate the coils and injectors are good?
There are 3 issues I can think of to cause gas to build up/not properly ignite in a cylinder:
- Low or no spark (I know I mentioned this)
- Leaking injector (and I mentioned this too)
- Compression problem/vac leak on that cylinder (possibly a valve problem).
So if you know it's not a plug/coil/injector, you're running out of options from what I see at the moment....
menaja19
14
01-02-2008 09:21 PM
