7th Gen ('06-'07): lower motor mounts broken
Old Oct 31, 2014 | 08:59 AM
Hognutsdeluxe's Avatar
Default lower motor mounts broken
How many lower motor mounts are there on a 2007 Monte Carlo SS? How much do they usually cost? How hard would it be to replace myself? and is $700 a good price, parts and labor for the shop to replace them?
Old Oct 31, 2014 | 01:15 PM
Mels SS's Avatar
Old Nov 1, 2014 | 06:19 PM
That's what I thought
Old Nov 1, 2014 | 10:12 PM
A lower motor mount replaced parts and labor $700, really. That seems way excessive for about maybe 2 hours labor and a parts. I would call around and get a second, third opinion for sure.
Old Nov 2, 2014 | 07:05 AM
Mels SS's Avatar
Way to much maybe a few hundred.
Old Nov 4, 2014 | 08:00 AM
$700 was the cheapest, Chevy wanted $1300. They have been replaced. But I'm still having an issue with it spitting, sputtering, surging and the RPM's going all over the place. I've replaced the spark plugs, and wires, new air filter, and new motor mounts. I did a scan with a code scanner and it came up with nothing. Could it be the throttle body? This all started after I added fuel injector cleaner, not sure if that's the problem.
Old Nov 5, 2014 | 11:51 AM
Mels SS's Avatar
Maybe the injectors got some junk in them. Or a bad O2 sensor
Old Nov 6, 2014 | 09:19 PM
sint3k's Avatar
Replacing the front motor mount is not that hard , Support the engine from above , unbolt transmission mounts and front mount , put jacks under sub frame , unbolt subframe bolts and lower the back a inch or so and then lower the front enough till you can get it out,
Also as far as your stuttering , can you tell me what your fuel trims are ? I need to know the long term fuel trim and short term , at IDLE, 1500 RPM , 3000 RPM please
A generic scanner should be able to give you those Fuel trim numbers
Hello Mel long time no see
Old Nov 7, 2014 | 04:34 AM
Well it turns out, it seems like it's a transmission problem. My wife drove it yesterday and when she put it in reverse it would not move, she put it in drive, it wouldn't move. She then turned it off, and restarted, she then put it in 1st gear,and it moved, also in reverse. this problem is intermittent, now its in the shop by way of a tow. When I put it on a scanner I got nothing.
Oh and by the way, thanks guys for all the help.
Old Nov 7, 2014 | 02:51 PM
Ill_Born_ss's Avatar
Just to make the above statement correct, Please read this thread and discover something much easier! https://montecarloforum.com/forum/en...r-mount-47692/
Mota1983
Aug 16, 2013 06:46 PM
mavrickf1613
May 22, 2009 01:46 AM
2000_BLACK_SS
Mar 15, 2008 09:21 PM
ExplosiveSoundz
Dec 1, 2007 04:06 PM
Hoosierdaddy
May 9, 2007 12:50 AM
