lower engine mount
Old 06-27-2010, 11:46 AM
machine2950's Avatar
thank s for the info,i just order from speed daddy,but most of the headers for the supercharged are 1 3/4 of primary tube , i also have a cadillac sts 97 and it s good for the scrap i take off the throttle body to put on my monty do i have to swap the maf and tps ???
Old 06-27-2010, 11:06 PM
nemesis's Avatar
2009 Monte Of The Year
is the sts a 4.0 Northstar engine?
you will need the throttle body, cable bracket, mass air flow meter, and tps connector harness. or buy one from zzp. https://www.zzperformance.com/grand_...=332&catid=108
you don't need the maf from the N* you swap the stock one from your monte to it. last but not least you will need the adaptor plate for the N*. as far as i know you will not find anyone making the 96-99 N* adaptor plate any more. if you seriously want to do this setup lmk cuz i might know someone still making or can make one for you. i'm running this old N* setup btw.
Old 06-28-2010, 09:59 PM
no the northstar it s 4.6 and i do have all the hardware (plug and braquets) but will need the adaptor ! if i can not find i will try to have one machined for me,might need more info about the vacuum plumbing under the n* TB
Dstevens
06-29-2013 11:29 AM
inssanity21
FWD Tech Guides '95-'07
26
01-11-2012 06:03 PM
denny8569
02-13-2010 04:10 AM
furcioelbraveado
01-05-2010 08:59 PM
2003supersport
11-03-2008 01:07 AM
Quick Reply: lower engine mount
