low coolant light
Old Apr 27, 2010 | 08:12 AM
MAMONTE's Avatar
My first thought was that you had a leaking LIM gasket. But, you just had that replaced, so thats not it.
Second thought (and pretty common actually) the sensor.
Old Apr 30, 2010 | 12:10 AM
dupree155's Avatar
Ok I had the dexcool flushed and the low coolant light still comes on could I unplug it for now? I reallly want to take it off and try to clean or replacee it but don't know how to get it off... does it screw off?
Old May 1, 2010 | 08:37 PM
RussellUCF's Avatar
2000 Monte- 3.8. I just replaced my Lower & Upper intake gasket TODAY! It wasn't that bad. It was may hours of getting to the core of the engine...but I tell you what- the gaskets were pretty bad. I mean, sludge was EVERYWHERE. the buildup of years of dexcool was also evident. But, the job is done...I pressure washed the lower manifold and its new again. I completely flushed the coolant system and added Prestone Dexcool. I am sorry to say sir, you have a long day of work ahead of you. You are trying a simple fix for a deep rooted problem...good luck.
Old May 2, 2010 | 11:32 PM
dupree155's Avatar
its probably just the sensor on the left side of the radiator i unplugged mine and the light went off til i get it replaced
Old Oct 20, 2010 | 11:38 PM
ETexasTwister's Avatar
Unhappy 2002 SS 3800 series II low coolant sensor
Well i put a new one on two days ago.It did not last 100 miles and is back on.It will come on and then off at intermittent times and now acts as if it is on to stay.
The one i am replacing it with is the lifetime warranty sensor from
O'Rilley Auto Parts.
Is it time to ask for my money back and go to GM?
Is there something I am missing? How about some kind of professional installation procedure.
hotrodharley
Nov 15, 2013 11:37 AM
TMoney
Aug 18, 2013 02:37 PM
dominic
Dec 3, 2008 11:48 AM
greatness107
Dec 10, 2007 02:08 AM
noob
May 24, 2007 10:43 PM
