Losing coolant, overheating
Old Jan 22, 2012 | 02:35 PM
gshugart's Avatar
Default Losing coolant, overheating
I have a 1999 Chevrolet Monte Carlo 3.1 engine, 82,000 miles. I have had trouble with it losing coolant. It started out as a slow leak and I could not see where is was leaking. The temp gauge would fluctuate...it would stay on normal, climb to halfway mark and then go back down. I would have to refill the reservoir once a day. Thought it might be the water pump, replaced it. Then it started losing coolant faster, you could see the leak, it looked like it was coming from under the alternator area and was not pulling coolant from the reservoir and the temperature gauge would climb and go almost to the hot.
Old Jan 22, 2012 | 02:38 PM
nitehawkjcb's Avatar
Sounds like you need to change your intake gaskets...
Old Jan 22, 2012 | 02:45 PM
KJRich's Avatar
Intake gaskets are a definite possibility.
crusher38
Jun 12, 2013 07:35 PM
jasonsmith
Nov 12, 2011 07:30 PM
artlawton
Jul 25, 2011 01:46 PM
SpinEm_90
Jan 25, 2011 07:10 PM
Ol skl SS
Oct 10, 2007 06:06 PM
