Leaking T-stat housing!
Old 06-15-2012, 08:13 AM
Franks 03SS's Avatar
2011 Monte Of The Year
Default Leaking T-stat housing!
So 2 days ago (I think lol) I noticed that my tstat housing has been leaking a tiny bit of coolant, it turned into nasty looking gunk around the edges :p so I decided to change my Tstat gasket and i noticed today that it's still doing it
My question is, can I used some RTV on the housing to seal it up some more?
Notice the yellowish gunk around the housing :p
Old 06-15-2012, 08:42 AM
03SSLE's Avatar
Clean the mating surfaces with a piece of sandpaper on a flatboard, then apply a thin coat of RTV to both sides of the gasket to fill any slight imperfections in the mating surfaces.
Old 06-15-2012, 08:49 AM
Did you file away too much making it shiny???
They make black RTV gasket sealer, use it
Old 06-15-2012, 08:52 AM
Well the housing doesn't have a gasket, just on around the lip of the thermostat which sits inside the LIM
Old 06-15-2012, 09:05 AM
03SSLE's Avatar
Sorry about that. I was answering an email about a SBC and had it on my mind. After cleaning the mating surfaces with a flatboard apply a thin coat of grease to the o-ring and a thin coat of RTV to the mating surface of the housing.
nope I only sanded lightly to clean up the mating surface
I wanted to polish it but I gave up haha I really need a dremel to get all the details
I'm debating wether I should get this right now or a tune up for monte
And btw look what I parked next to yesterday haha yep it's a purple one
I'm think I should get the red one? Lol
Old 06-15-2012, 09:08 AM
Lol it's all good and yep I'm buying the red RTV , it's high temp Haha
Old 06-15-2012, 09:10 AM
Budsjlm's Avatar
I always use black, I have used stuff that stays flexiable and ended up leaking again
Old 06-15-2012, 09:13 AM
I already bought it I guess I could give this a try, it's only $5
Old 06-15-2012, 09:23 AM
Did I say black a few posts ago
I hope the red works for you lol.
Isn't that a beautiful purple?!?!
Quick Reply: Leaking T-stat housing!
