6th Gen ('00-'05): L36 Build Sheet
Old Apr 7, 2012 | 03:17 AM
BigPana's Avatar
Question L36 Build Sheet
Has anybody tried this or have any knowledge of this build plus are the HP numbers correct ?
http://www.zzperformance.com/blog/bu...-supercharged/
Old Apr 7, 2012 | 06:35 AM
Lol that is my build, but I have even more! No the numbers are exaggerated and a sales claim and a little deceiveable. For example the hv3 does give about 20 hp, BUT it is 20 hp in the upper rpm band where your hp drops about 20-25 already and it is just helping restore it.
With all of that you would have a more responsive car, and you would be pretty happy imo
Old Apr 7, 2012 | 07:07 AM
BigPana's Avatar
Thanks for the input Chibi, been looking at this sheet over and over since I bought the car ! Lol
Old Apr 7, 2012 | 11:46 AM
zipper's Avatar
I agree with Chibi. Coming from an NA background though, I recommend skipping the NA build altogether and go boost. You can do an engine swap for the cost of the engine if you do it yourself ($150-$750), do a top swap with all the needed parts (less then $1000), or find a good used turbo kit ($2000 or less). If I were to start all over again, I would just go turbo. You can make 400hp by keeping everything else stock, all you would need is the kit. That's a great deal, especially when you consider that that goal is impossible in NA form, and very expensive in M90 form.
But if you want just a slightly better feel/response out of your Monte and nothing else, I would just throw in a set of rockers and call it a day. But if you plan on going beyond that, then look at boost.
Old Apr 7, 2012 | 01:52 PM
tps221's Avatar
lol i want a cold air intake for my 3100 but i know i gotta do it custom is it worth it?
Old Apr 8, 2012 | 02:17 PM
turbo monte's Avatar
i agree with this 100% but on a bone stock intercooled turbo setup i dont think you will get 400whp probably around 320whp-350whp is where you will sit but that all depends on what kit you buy and what turbo you have. my monte with bone stock engine and a intercooled cartuning kit was right around 320whp. i have a completely built engine and trans now still running the cartuning kit and made 384whp (maxed out the maf or probably could of seen just over 400whp) if you go with a z7 kit you will probably be around 350whp stock engine and trans.
Old Apr 9, 2012 | 08:50 AM
I am going turbo eventually, I did my build because it all helps with the turbo down the line
Good luck with your build, however you take it!
Old Apr 9, 2012 | 08:24 PM
zipper's Avatar
I know I'm being picky here, but I never said 400Whp, but 400 hp (which would be around 320-350whp) One person in particular who I can think of with a Grand Prix that was impressive was Kuntzie. I don't know how he did it, but every step of the way with his project he made great whp, even when you consider that he did a 5 speed swap. If you can find out what all he did, you would be golden.
GENTLEBEN
Aug 2, 2014 10:52 AM
GENTLEBEN
Jul 31, 2014 10:54 PM
martinezp
May 3, 2011 01:00 PM
DreamCar69
Feb 24, 2010 09:36 AM
06BlackSS
Jan 2, 2009 03:19 PM
