Power Steering pump removal
Old Oct 14, 2009 | 09:55 AM
mperko86's Avatar
Default Power Steering pump removal
Someone please help. I can't get the power steering pump out of my 2001 Monte Carlo SS. I have it disconnected but it seems like there is no extra room to take the pump out with out taking the pulley off before i remove it from the car. But I can't get down in there to use the pulley puller. I've tried taking off the front passenger side wheel no help. I tried taking off the alternator for more room still no help. Any advice on this would help. Thank you
Old Oct 14, 2009 | 12:05 PM
jhartley's Avatar
would rolling the motor to the front help and give you the extra room to get it out. I know if yours is like my 02 ss i have yet to see my power steering pump the only way that i can check the level is by blindly feeling around
Old Oct 15, 2009 | 10:32 AM
mperko86's Avatar
Rolling the motor forward would of help because I only needed a 1/2" or 1". But I did get it out, I had to take off the ECM, Radiator reservoir, alternator, and the battery just to give me enough room to get my big hands down in the engine bay. I had to take the pulley off before i removed it from the engine bay but after I disconnected everything from it. I had to do the same thing to the new pump I put it down in the bay and then I installed the pulley, mounted it, and reconnected the lines. The car is running great now, no more loud whining noise for me. The job was not that hard. It only took a couple of hours and a few small cuts on my knuckles.
Old Oct 15, 2009 | 10:40 AM
mperko86's Avatar
The power steering pumps suck on there cars. I bought this car with 6,000 miles on it and it now has 76,0000 miles on it. This is the 5th power steering pump I have had replaced on it, (the first that wasn't covered by the warranty and I had to do my self). I have also changed my power steering pressured line 7 times on this car, it seems like when it is really cold out side it can't take it and it blows(it just can't take these Chicago winters). I guess if I bring this car back to Cali I won't have there problems.
Old Oct 18, 2009 | 03:01 PM
montes my python's Avatar
when you get it changed, flush the system with clean p/s fluid, and put in a p/s filter, I believe the part # is psf1 from ARC, just splices into the return line with a couple of clamps and stops the grit that ruins the pumps and rack seals, doesn't take up much room either, use the fluid GM recommends, don't use ATF
Aaron
Old Oct 18, 2009 | 06:39 PM
5 power steering pumps and 7 high pressure lines in 75,000 miles is definitely not normal; something is seriously wrong somewhere in that system. I've heard of them going randomly, but thats far more failures than any other 3800 I've ever heard of.
Old Oct 19, 2009 | 09:36 AM
mjv247's Avatar
My car is making that winey noise also but i was just told to give it some p/s fluid and it should stop. Do you think i should change the pump also? I have an '05 LT.
Old Oct 19, 2009 | 09:41 AM
MAMONTE's Avatar
If you are low on P/S fluid, then it might be the cause of the whine...
But if your not low, adding fluid is not neccesary, and could be a bad thing if you add to much.
I would say its probably the p/s pump. Mine went bad in my Monte at around 70K
Old Apr 9, 2012 | 11:04 PM
Brad Mayfield's Avatar
My PS Fluid is leaking like the Niagara Falls going make an attempt tomorrow morning to pull this out I hope and pray its only 2 hrs!
suburbiangiant
Dec 24, 2013 01:17 AM
Harlan2012
Apr 21, 2013 05:03 PM
24_48Fan
Jan 13, 2007 07:49 PM
Gr4v3_7
Dec 6, 2006 05:34 PM
