Keeping my 454 BBC cool...
Old Jul 30, 2020 | 04:29 PM
Jeff Palmer's Avatar
Default Keeping my 454 BBC cool...
Any advice would be much appreciated...I just bought a 1972 Monte with a 454 and Stealth EFI. The cooling fan is belt powered. I am wondering if I should go for a secondary fan on the front of the radiator or swap out the original fan with an electric. I am not used to the heat a 454 puts out and I don't like seeing that temp hitting 200 in traffic.
Old Jul 30, 2020 | 05:27 PM
volkerc's Avatar
Just adding a fan in the front might not get you the results you want. You would have to check for push and pull. Make sure you have a fan shroud. On my souped up 400 Pontiac, i run a constant, no clutch, belt driven flex fan with a 4 row core radiator, no overheating at all.
Mgw2k20
May 5, 2021 06:11 PM
73monte496
Oct 1, 2014 12:15 AM
thewhitestcarlouknow
May 6, 2014 08:48 PM
87montelS87
Sep 14, 2010 11:15 PM
Mike03R1
May 15, 2010 10:06 PM
